Gasket Removal Help: Is This OK?
Old Dec 31, 2012 | 11:59 AM
andlours's Avatar
So I'm in the process of replacing my timing chain and cover. I got the new timing chain installed and am currently trying to remove the old gasket. I swear though, this gasket was glued on like none other. I've been using a razor blade, gasket scraper, gasket remover, and a dremmel with a wire brush attachment. I've gotten most of it off except the two bottom corners. The gasket is pretty smooth with the surface in both corners. Would it be OK if I left it? or should i just put in an extra day to fully remove it?
Cheers,
Andy
Old Dec 31, 2012 | 12:27 PM
B-Fake's Avatar
It only has to come off if you don't want it to leak . I know it's a pain in the a$$, but if you take the extra time to do it right it will be worth it. If you put it back together as-is it will leak and you'll have to take it back apart and scrape it off anyways.
Old Dec 31, 2012 | 01:09 PM
Toyota~Boy's Avatar
Very well said..... I would defiantly take the extra time man. An oil leak will only lead to a dirty engine bay or a blow engine. I would go ahead and remove it even if its hard or takes longer.
No one told George Washington it would be easy to start a colony but he still done it. And look its still here. May have problems but its still here lol
Old Dec 31, 2012 | 01:14 PM
andlours's Avatar
Hey, thanks for the help guys. I'll just spend the extra time and do it right. The last thing I want is to run into problems and have to disassemble everything again.
Sep 4, 2015 09:27 AM
irritech
Jul 27, 2015 05:15 PM
scottyg486
Jul 19, 2015 05:34 PM
Snort
Jul 19, 2015 07:03 AM
Snort
Jul 9, 2015 03:58 PM
