Fuel Lines
Old Oct 4, 2010 | 01:08 PM
peow130's Avatar
Fuel Lines
Okay i gotta question.
And i've searched the crap out of google.
Do i NEED to run hardlines for my carbed 22r im dropping into another vehicle?
Or can i run soft fuel injection line all the way to the gas tank?
Another question..
The 22R has a mechanical fuel pump, right?
If not, i would need to run a fuel pump..
Old Oct 4, 2010 | 01:19 PM
xxxtreme22r's Avatar
fuel injection line is fine as long and you anchor it down so it doesn't move around as the mechanical fuel pump sucks the gas through. Kinda like how a soft brakes line moves, just not as much. FYI, from the fuel pump pickup to the hard like it's rubber hose and then from the hard like it becomes a soft hose again. Just remember you have a supply line and a return line from the fuel pump which is internally regulated by way of the return line. Although, you don't need the return line if your running a weber as the install instructions require you to block the return line off.
EDIT: I would also ensure that nothing is gonna cut the soft hose anywhere under the truck, so tuck it well.
Old Oct 4, 2010 | 01:28 PM
peow130's Avatar
Well i was going to de-smog my early 22r i pulled out of my 81. Maybe i should consider a weber as it seems the setup would be easier.
And i planned on running the soft line on the inside of the frame rails on my willys all the way to the back.
So, the aisin carb does have a mechanical fuel pump and i don't need to wire in a electric pump?
Now the next question is if a cj5 tank/pickup will work with the 22r lol.
Old Oct 4, 2010 | 02:03 PM
no electric pump needed. although, the electric pump with an external regulator like a holley would work better for the weber setup.
couldn't help you with the heep stuff though. lol.
Old Oct 4, 2010 | 04:57 PM
peow130's Avatar
Lol well it's all toyota crap anyways.
Neighbor gave me an 18 gallon fuel cell lol, dont need to get a CJ5 tank at all.
He even has some acid stuff i can use to clean it out!
pyramid
Jul 30, 2015 10:05 AM
Poppie51
Jul 23, 2015 05:03 PM
Hiluxtrucha
Jul 22, 2015 10:00 AM
Poppie51
Jul 16, 2015 06:16 PM
Fundy Rider
Jul 16, 2015 01:35 AM
