Which is Cold idle/wam idle (Pic included)
Old Aug 14, 2011 | 06:21 PM
stealyophace's Avatar
thanks
Attached Thumbnails Which is Cold idle/wam idle (Pic included)-img_4250.jpg
Old Aug 14, 2011 | 06:43 PM
dropzone's Avatar
Fossilized
My crystal ball is cracked-what engine/truck type/year?
Old Aug 14, 2011 | 07:02 PM
haha ya sorry i guess i figured someone would know its an 86 22r
Old Aug 14, 2011 | 07:05 PM
xxxtreme22r's Avatar
#1 is your slow idle speed
#2 is your fast idle (must be on the choke to adjust)
#3 I forget, I never touched mine. I think it's to adjust when the secondary plates open but I could be wrong.
#4 do not touch, that's your idle mix screw.
Old Aug 14, 2011 | 08:07 PM
what do you mean by on choke, how does one engage the choke on a truck? ( i have only had a yamaha blaster 4 wheeler that i have tooled around with for my knowledge about engines)
so if my engine has problems right when it starts cold of idling properly i would adjust the cold idle yes?
right when it starts it sort of sputters for a few seconds then if i lightly touch the gas it will stall, but if i sort of press it quick and aggresive and pull it off then it jumps up and will idle ok, but its really annoying every time i start it from cold, and sometimes it takes a few seconds for it to turn over to
Old Aug 15, 2011 | 03:24 AM
it's a carb'd truck, three presses to the floor on the gas pedal start truck. If your not hitting the gas pedal to the floor prior to starting then it is what is most likely tyour problem. Pushing the pedal to the floor is what normally engages the choke, another way to manually do it is hold down the choke plate by hand and turn the throttle until you hear a click.
Time to get yourself an FSM (Factory Service Manual <<< right click save as ) and also read THIS.
Old Aug 15, 2011 | 09:47 AM
ya the previous owner never supplied me with that little tid bit about pressing the pedal down, i have read that FAQ before but I will again. Thanks for the service manual
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
jerusry
Oct 19, 2015 05:28 PM
Sep 4, 2015 09:27 AM
calderp
Jul 27, 2015 09:58 AM
ty1er
Jul 19, 2015 06:42 PM
