Clutch...maybe?
Old Mar 6, 2010 | 01:25 PM
Mikeb44's Avatar
Clutch...maybe?
The other day I was wheelin my 86 yota pickup and I was in this hole and gave it some gas and then it wouldnt move. I push the clutch in and put it into first and it wont move. so is it the clutch or something else..the motor is running but just not moving so i know its somewhere in the tranny or tranfercase.
Old Mar 7, 2010 | 12:02 PM
myyota's Avatar
Before this happened could you smell the clutch getting hot at all ?, if so then its possible that you burned up the clutch, and that would be a cheap fix. If its not that then you might have broke the output shaft in the transmission.
Old Mar 10, 2010 | 08:32 AM
Mikeb44's Avatar
yeah I could smell it alittle bit and even now when I start it up and push the clutch in and rev it up i can smell it
Old Mar 11, 2010 | 08:17 PM
myyota's Avatar
Well, it sounds like the clutch is gone, you will need to pull the transmission to check it out.
