View Poll Results: Change to syn. oil in high milage trucks
OK
159
74.30%
not OK
55
25.70%
Voters: 214. You may not vote on this poll
Old Mar 30, 2016, 02:00 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Toyota Tacoma Engine Guides
Browse all: Toyota Tundra Engine Guides
Print Wikipost
Change to synthetic oil on high miles truck
Old Mar 5, 2003 | 08:12 PM
Victor's Avatar
20w50 seems really thick for these engines. Unless you aren't getting good oil pressure with 10w40 then that stuff is probably not flowing well at startup and actually increasing wear inside the engine. If your oil pressure is that bad its probably time for a rebuild anyway. A good compromise is the 5w40 synthetics I mentioned before. You'll get good flow at startup, thicker oil for oil pressure, and its synthetic so you'll have longer oil change intervals. You'll make mother nature happier with those and probably find less wear on the engine and better gas mileage.
Old Mar 5, 2003 | 08:40 PM
trd90toyota's Avatar
Originally posted by Bumpin' Yota
While we are the topic of oils, what doe the numbers in oil mean?
like 5w40 10w40 20w40 20w50 etc....
Steve
I think this link will help you out:
http://www.vtr.org/maintain/oil-overview.html
Old Mar 6, 2003 | 01:13 AM
jx94148's Avatar
This oil seems to get brown a lot faster than the old Havoline 10w40 I was using before, but it could just be me too. Time is proceeding far too quickly.
Steve
Are you using the same filter as you did before? A good filter and bad oil will turn brown just as fast as good oil and a bad filter.
I started using synthetic at 190,000 miles. My motor got quieter and at high RPMs it seems happier with it. I seem to have a bit of seepage at the valve cover gasket. Not a leak, just a seep. Its an old motor with old gaskets. It should be allowed to seep a little if it wants. I'm not worried about it.
FWIW I put in Costal full synth 5w-30 from Auto Zone. $3.49 per quart. I use Purolator filters from Pep Boys. That combination is good for 5000 miles between changes and the oil is still somewhat gold in color, not black like dino oil and nasty ass Fram filters did for me at 2500 miles. I do add a quart at around 3000-3500 miles between changes. Like I said its a high mileage motor at 201000 now.
Old Mar 6, 2003 | 01:22 AM
Woodbert's Avatar
It gets really hot here 90-95F and I'm going to try 15-40 Mobil 1 with a TRD filter.
I tow a Jet Ski that is around 100 lbs toughn weigth and about 1200 lbs.
Is that OK???
Old Mar 6, 2003 | 04:56 AM
  #25
Victor's Avatar
If you never plan to drive in cold weather at initial startup then 15w40 might be ok. Seems like 5w40 or 10w40 will flow better at startup.
The first # is the viscosity when cold. In the case of 5w40 its 5 which is very thin. Should flow very well. A 15w oil or 20w oil is already quite thick and won't flow the same for the crucial first few seconds after startup.
The second # is the oil's weight once it is at its operating temp which is different than the engine normal operating temp. The oil will thicken as it heats up due to viscosity modifiers added to the oil. The thicker oil stays put against cylinder walls and on camshafts better thus protecting them.
To max out the life of your oil, and subsequently the engine, do NOT idle your car to warm it up. The oil will not flow well in the engine. Drive slowly and don't gun the engine. During these warmup minutes the oil viscosity is adjusting as the engine heats up and excess moisture is being burned off. Letting the engine idle excessively after startup is the biggest thing you can do to increase wear.
Old Apr 3, 2003 | 07:25 AM
  #26
Ryd's Avatar
Ryd
Learn something new everyday...
I didn't know that...
I'd always accepted the common practice of letting an engine warm up to operating temperature at idle. This is bad?
Ryd
Old Apr 3, 2003 | 07:42 AM
  #27
Victor's Avatar
Idling is not good for the engine. If we are talking extremely low temperatures then yes idling may be good but as a rule of thumb you shouldn't do it. You don't make enough oil pressure at idle to get oil to the top of the engine where your camshafts and valvetrain are. Drive slow for the first block or two. Idling the engine in the driveway also doesn't put the engine under load which is necesary to get oil circulating faster.
Old Apr 3, 2003 | 07:50 AM
  #28
Ryd's Avatar
Ryd
And I am enlightened by the turtle
Does this "idle is bad" rule apply for warm engines as well or is it most important for start-up? Taxis idle all the time...
Old Apr 3, 2003 | 07:54 AM
  #29
Victor's Avatar
Once the engine and the oil are up to temperature than there is no further wear. What is increased is emissions and fuel waste. The ambulances and fire trucks at work are all diesel and we idle them for long periods of time. Ever notice that at truckstops or on the side of the roads the truckers have their engines running while they rest? Some engines take a long time to warm up and they waste more fuel for the first few minutes than if the vehicle was just left idling. The benefit of power for the microwave and TV is obvious as well as having A/C.
Old Apr 3, 2003 | 08:11 AM
  #30
rimpainter.com's Avatar
And idling helps the huge turbo's in the big rigs cool down properly. I guess its their version of a Turbo timer.
Old Apr 3, 2003 | 08:37 AM
  #31
FUGGRWE's Avatar
I started using Mobil 1 in my 4Runner when it had 90k on it, and I have no idea what the previous owned used. My mechanic told me as long as you have a tight engine; no leaks, and good compression, it's okay to start using synthetic.
  #32
Brown's Avatar
Originally posted by trd90toyota
I belive that Valvoline has the cleanest oil (non- synthetic oil) out on the market. if you pour it out in to cups and compare it to, say, Penzoil or Quaker State (both Penzoil and Quaker State are made by the same company), the Valvoline looks much cleaner. So my vote is for Valvoine.
I don't agree with this method of looking at the cleanliness of oil-- because the types of oil and bases that compose these oils are different. It's like comparing Miller to Sam Adams to Guiness-- which beer is cleaner? Miller because it looks lighter and cleaner? Just thought I would point this out-- not trying to be a jerk, but the logic is a little flawed.
Someone else stated that a certain synthetic is paraffin based. Correct me if I'm wrong, but if it's a synthetic, then how can it have a dino oil base? Doesn't make sense to me.
Old Apr 4, 2003 | 09:10 AM
  #33
runningman's Avatar
Smile synthetic
CHANGING TO SYNTHETIC IS FINE UNLESS YOU HAVE ANY SORT OF LEAK OR SEAL DAMAGE. HAVE YOUR VEHICLE CHECKED OUT FIRST BY A CERTIFIED MASTER TECH.
Old Apr 4, 2003 | 09:11 AM
  #34
Tatsuo's Avatar
I'll chime in. I just changed from dino to synthetic at 202,000 miles. I now have 208,000 with not a single problem. I know its only 6,000 miles, but i've only had the truck for a month.
Old Apr 4, 2003 | 12:41 PM
  #35
Doing burnouts with 202K miles? Good choice in changing to synthetic!
Old Nov 12, 2003 | 07:59 AM
  #36
sandcrawler's Avatar
FWIW: i switched my 93 to mobil 1 10w30 at 108k-ish and now, at 119k, i'm dealing with a pretty good leak: from the rear main seal or cylinder end plugs.
i believe the potential for the leak was there already, though. and now the smaller particles of synth are just sneaking out. it looks cleaner inside the oil fill cap and the engine is sure quiet and smooth now.
also, my oil pressure drops significantly as the engine warms. i think mobil 1 10w30 is pretty thin for a 30. i will be doing a flush and switching back to dino. will see how that works.
Old Nov 12, 2003 | 08:17 AM
  #37
Tatsuo's Avatar
At 220,000 now with no leaks... but on the third set of tires.
Old Nov 12, 2003 | 08:44 AM
  #38
romus's Avatar
A great link on motor oils, oil filters & gear oils.
http://theoildrop.server101.com/cgi/ultimatebb.cgi
Old Nov 12, 2003 | 12:52 PM
  #39
JSharp's Avatar
I was going to make the same suggestion. Info on all of the questions in this thread come up daily on that board...
Old Nov 12, 2003 | 02:04 PM
  #40
and i should have mentioned that the flush i'm going to do is with Auto-RX: which i'm using due to the crazy # of excellent reviews i've seen on the "BITOG" forum and thru independent web searches.
gotta switch back to dino oil to stop leaks, though, which i'm not crazy about. but, based on the opinions of people on the board with a helluvalot more oil skills than yours truly, i guess i'm tilting at windmills.
if i have a good experience, i'll be sure to post results here.
