CEL Code 71 Question
So I have a code 71, EGR problem... I recently installed a catback (which came with and is using bolt on U-clamps? I think they're called...) anyways... Would a leak from this system cause a code 71 CEL message?
Nope, sure wouldn't.
That's an EGR gas temperature sensor code. Which means the EGR valve is malfunctioning, the VSV for the EGR is malfunctioning, and/or there's a open/short in the sensor or VSV circuit. Could also be a fault in the ECU possibly, but that'd be the last on the list of things to check.
Here's the good stuff.
http://personal.utulsa.edu/~nathan-b...00egrgaste.pdf
http://personal.utulsa.edu/~nathan-b...77exhaustg.pdf
http://personal.utulsa.edu/~nathan-b...85diagnosi.pdf
nframe
3.4 Swaps
Aug 16, 2015 09:03 AM
