A/C Fan Problems
Old Apr 14, 2006 | 08:35 AM
joshik's Avatar
A/C Fan Problems
Hey guys... been having this problem for some time now but its gradually getting worse.
the fan for the a/c, the first 3 settings do not work. Lo * * Hi. The fan will only turn on when you switch it to high. what do you guys think it could be?
also, my a/c doesnt work either. the air doesnt get cold. before, when you have the fan on, and then push in the a/c button, you can hear the engine rev up but now, the engine doesnt rev up at all. does that mean the a/c isnt turning on or because its out of freeon (if thats what it uses)... what do u guys think?
i'm a roll down the window type of guy but dang, it sucks to be hot wearing a suit to work.
Thanks!
Josh
Old Apr 14, 2006 | 08:46 AM
Haston's Avatar
Regarding your problems with the fan, it's probably the resistor, portions of it burning out. Check out 4Crawler's website. He has a detailed description of the problem and the fix that has helped many, including myself on my 1st gen. It's an easy repair. A new resistor for my truck was about $15, as I recall.
One caveat: it's probably the resisitor so long as the fan doesn't work when you use the heater, as well. If you're fan speed problem is solely related to the a/c, then you can probably count the resistor out.
Hope this helps. Let us know what you find.
H
87 4R
95 4R
Old Apr 14, 2006 | 08:49 AM
joshik's Avatar
cooool! thanks for the info! i'll check that out. yeh, its for both the ac and heater.
thanks!
Old Apr 14, 2006 | 08:53 AM
Haston's Avatar
Ah, then you;re in luck. A $15 plun-n-play repair is always good for the ego and the wallet. As for your a/c issue, I had to get my 87 a rechartge last summer. The first place I took it to couldn;t get it right the first three times. I got a recommendation for a differnet shop and they fixed it in the first. It;s nice rdinbg in an old truck with a good working a/c unit. I think the recharge was about $150 for the service and some parts- Keep in mind these are DC-area prices (always high; gas at $3.20 for premium this morning). Anyway, good luck. H.
Old Apr 14, 2006 | 09:22 AM
joshik's Avatar
thanks for your help!
i just called the stealership, $47+tax for the resistor!
coryc85
Sep 9, 2015 06:24 AM
jackiebrownia
Jul 20, 2015 09:02 AM
TURBOrunnerNM
Jul 20, 2015 08:31 AM
1996Taco
Jul 20, 2015 12:02 AM
bryan34w
Jul 6, 2015 05:53 PM
