Bending leaf spring retainer back
Old Mar 30, 2007 | 07:11 PM
drguitarum2005's Avatar
From: Houston (home), Atlanta (school), Cincinnati (work)
I tried searching for a long time with no luck. it probably doesn't help that I can't remember the name of the part. Anyway, I'm wanting to unbend the little retainer on my leafs that keep the individual leafs from spreading out too far (and keep them from twisting out of the pack). I want to unbend them straight up and put a bolt through them like i've seen on several occasions. How do I do the bending? It's some thick steel and with all that plastic around it, if I use heat then it just melts the plastic. If I have to take them off, I can't quite see how to do that. thanks!
Old Mar 30, 2007 | 07:12 PM
Marc P's Avatar
I used a vice when I made my leaf packs.
Old Mar 30, 2007 | 07:22 PM
Ringmaster's Avatar
Their held in the upper or lower leaf with a rivet, which is peened over when the packs are assembled.
Drill out the rivet from the bottom with a 1/4" bit, and try to break it free from the leaf.
You may have to go to a larger diameter bit to get the whole rivet out.
Or just grind the head off the rivet, easier, and then pry it off.
Wear safety glasse's/goggles.
Old Mar 30, 2007 | 07:54 PM
how do i get it back on if i destroy the rivet?
Old Mar 30, 2007 | 07:58 PM
Ringmaster's Avatar
The newly drilled hole with the bolt ontop, will hold it in place. Beat it down towards the axle as far as you can, then tighten the bolt.
Jun 1, 2021 01:51 PM
87blyota
Jul 10, 2015 04:31 AM
Nickdigg
Jul 7, 2015 06:04 AM
toyoda8488
Jul 5, 2015 10:18 PM
elwood73
Jul 5, 2015 07:07 AM
