Aftermarket spring perch question
Old Mar 26, 2012 | 02:49 PM
85TurboRunner's Avatar
I need to re-do my rear spring perches due to a bad pinion angle and as I was looking for other options beside Marlin , TG etc. I found these guys at summit
http://www.summitracing.com/parts/SUM-720025/?rtype=10
Anyone try these things. They don't seem to be as long as the brands mentioned above but they are less then half the price.
I know I'm kinda being cheap here.
Old Mar 26, 2012 | 03:12 PM
BMcEL's Avatar
You could just use shims instead of moving the perches. How bad is the pinion angle?
Old Mar 26, 2012 | 03:52 PM
The springs are already shimmed. It might actually help if I take them out.
This is how it looks right now. I get vibes mainly on decelleration.
I put new u-joints in it when I got it so that shouldn't be an issue.
Old Apr 30, 2012 | 03:13 PM
rattlewagon's Avatar
Defiantly take the shims out.
And read this: http://www.4crawler.com/4x4/CheapTri...line-101.shtml
Old Apr 30, 2012 | 04:15 PM
Took them out a while back and the vibes are gone. Guess I should have updated this.
Kinda weird I ran those same rear springs on my 4runner and had no issues.
Guess the added wheel base of an xtra cab threw things outta whack?
Oh and thanks for the post but the reason I made this thread is because I already knew my angle was messed up.
delmert
Sep 30, 2015 04:34 PM
Sep 4, 2015 09:27 AM
coffey50
Jul 28, 2015 10:55 AM
Nickdigg
Jul 7, 2015 06:04 AM
Suprarossa
Jul 6, 2015 05:21 AM
