aftermarket cam
aftermarket cam
idk if im in the right section to post my question....but i recently got two after market camshfts from a friend of mine. i planning to put a cam in my 22re. but i wanted to find out the lift and durations of this cams and the difference of the stock cam. first cam is a "norris 309". the second cam i dont know what brand it is. but on the front its stamped with a bunch of numbers "5246".
can anyone tell me the lift and duration of the norris cam? and if anybody know what kind of brand is the other one, if you know the lift and duration also. and whats the difference compared to stock.
any input is greatly appreciated.
You know of no one that can do this for you ??Anyone could quote you numbers but without you being able to double check those numbers yourself.
Even new cams out of the box can get boxed wrong or even just ground wrong like on Hang over Monday after the Super bowl.
If your into changing Cams it is best to be able to measure them yourself so easy to get taken advantage of.
kawazx636
Oct 6, 2021 03:03 PM
TheBFA
Feb 15, 2020 06:55 AM
LittleUgly
15
Jan 2, 2020 01:30 PM
SpookyMulder
Nov 4, 2015 11:56 AM
Just curious you have the cams Why don`t you measure them yourself??
