99 tacoma 3.4 V 6
Old Aug 15, 2016 | 11:19 AM
1harryjf's Avatar
99 tacoma 3.4 V 6
I replaced water pump and timing belt. I turned crank until notch was on O mark made sure timing notches lined up on both cam gears with the #3 timing cover behind. When I tried to start engine it runs for 5 to 8 seconds then sputters out. I'm sure I lined all correctly. There are yellow paint marks on cam gears and timing cover. Should I line these up instead of notches!
Old Aug 15, 2016 | 12:36 PM
wyoming9's Avatar
Do you have every thing back together ??
Forget to plug something in MAF sensor ??
If your timing was off it most likely would not start at all
Old Aug 15, 2016 | 05:44 PM
1harryjf's Avatar
Is the MAF sensor the same as crank shaft position sensor
Old Aug 15, 2016 | 10:51 PM
wyoming9's Avatar
No!! not even close it is in the air intake
Old83@pincher
Feb 20, 2016 04:24 PM
Mikkydee
Jan 27, 2016 03:23 PM
Krash
Apr 14, 2003 08:41 AM
PAVEYOTA
Jul 21, 2002 08:25 AM
taloolarunner
Jul 20, 2002 05:51 PM
