5VZFE 3.4 Timing Belt Confusion
My problem: I am trying to finish up the preventative maintenace on a 5VZFE before I swap it into my '88 runner.
My problem is that I install the new timing belt with crank timing marks aligned at 0 degrees (straight up) and both cam gears at 0 degrees (straight up as well) then I install the belt with the three belt marks right on the cam gear marks and the crank mark and they all align. I release the hydraulic tensioner and everything is still good. The problem is that when I turn the motor over by hand a full rotation, the timing marks are now one tooth to the right (clockwise facing the motor) on both cam gears and the crank gear. If I turn it over a full rotation again, then they are off by two teeth. I have tried pulling and re-installing it 4 times and same results. Is this supposed to be happening? I am assuming that they should be realigning back up when the motor goes around a full cycle.
How could they be aligned when I start, then all go off by a tooth each rotation? Any help would be appreciated. I am guessing that the actual belt marks are for initial setup and are ignored after installation?
that's fine, the belt is gonna be 1 tooth off at all the marks as i remember but look at the cam an crank marks should still be right, that same thing got me for like 5 hours, just don't pay any attention to the marks on the belt except for when u put it on the first time the belt marks are not gonna line up again after u turn the motor
Thanks.
Sweet, thanks guys. Thats what I thought, but I guess I was looking for a little confirmation.
They really should mention this fact in the FSM since I believe the factory belt has the marks as well.
