5 speed fluid....?
Old Jun 19, 2006 | 02:09 PM
gregbreakseverything's Avatar
so you need a big hose to fill it? How much fluid do i need?
Old Jun 19, 2006 | 02:25 PM
Glenn's Avatar
Originally Posted by AH64ID
When you drain be sure to take the fill plug out first, otherwise when you pull the drain plug it will spash everywhere when it sucks air back in...
Good idea... The main reason I always remove the fill plug first is that if it's stuck, I want to know about that before I need to add oil.
Old Jun 19, 2006 | 02:26 PM
AH64ID's Avatar
Look Here and get one of their pumps to do it...
Old Jun 19, 2006 | 02:27 PM
AH64ID's Avatar
YEAH, I know that one.... good thing I removed it first....I had to wait until the tranny was out for a clutch to get enough torque on the plug to get it off...
Old Jun 20, 2006 | 09:16 PM
  #25
SH0ck-D's Avatar
Originally Posted by spaugh
is it necessary to flush when going to synthetics? Or can I just drain and refill? I don't know what kind of oil in my transmission now, but I would like to change it since the car is used and I doubt the previous owner had it done.
you're transmission and differential fluids will usually last you a long time 30K+. If you are thinking of changing to synthetic motor oil, than no, because there is no direct connection of the fluids from the motor to the transmission. I do believe however that all of your differential and transmission fluids should be synthetic based.
David
Old Jun 21, 2006 | 04:04 AM
  #26
OutdoorLiving's Avatar
Changing the oil is rediculously easy. I put Valvoline in mine, haven't had any problems. Changed both the transfer case and the manual transmission at the same time. Took me about ~40 min start to finish.
If I had it to do over again, I would use a HAND PUMP to put the oil in instead of the syringe contraption I currently have.
Oh, and be waiting on that oil. Bob has a great writeup on it. And he ain't kiddin about saying it comes shooting out like a missile either!
I used THIS guide.
Old Jun 21, 2006 | 06:32 AM
  #27
AH64ID's Avatar
Nope, as there is no real way to flush a manual tranny, thats an auto thing. You want to make sure the oil is warm (flows better), and drain it... I do usually leave the drain out for the first two pumps to clean out a bit more...but not necessary, if the fluid is warm and the truck was just driven the particles will be suspended and drain out the bottom...
izzmee
Aug 17, 2015 10:20 AM
91yotapup
Aug 17, 2015 09:40 AM
129Creepin
Aug 5, 2015 10:12 PM
kyletbert
Jul 17, 2015 11:39 AM
wilbertd
Jul 6, 2015 07:39 AM
