22re problem
Old Apr 10, 2012 | 10:21 AM
OMGitsBigCheeze's Avatar
22re problem
I'm putting this here because it doesn't really have anything to do with making my truck better, just running.
I just got this truck it runs good I did a donut in the mud, took it home and now when I turn the key the starter doen't crank and it says check engine. Only thing I can think of that I did that might have caused it is I adjusted valve lash and I didn't check the timing before I started running it, but I've only gone down the street and back since, and done the donut.
I don't see how the starter could have gone out so suddenly, anyone got any clues?
Old Apr 10, 2012 | 11:10 AM
Inferno451's Avatar
Check your connections to the battery and make sure the battery's good. Take it from there.
Old Apr 10, 2012 | 11:15 AM
Terrys87's Avatar
Did you check the little wire on the starter? Should have 2. One from the battery and the other is a brown tabbed/clip wire.
Old Apr 10, 2012 | 01:36 PM
Ya the battery is fine and the wires are there, the wire from the battery to the fuse box looks pretty bad tho.
Old Apr 10, 2012 | 09:14 PM
Somthins up with the ignition switch . . .
thanks for the input
jbv808
Aug 6, 2021 04:47 PM
steve miller
Oct 10, 2015 01:40 AM
Odin
Jul 15, 2015 09:28 PM
Sandman
Jul 14, 2015 12:36 PM
ryerye13
Jul 14, 2015 08:27 AM
