Tips & Tricks Tips and tricks to make the site easier to use such as posting pictures, where to host them, and avatars
Wiring turn signals into parking lights
Old Oct 22, 2017 | 08:20 PM
Victor Jackson's Avatar
Lightbulb Wiring turn signals into parking lights
Ok so I got in an accident and it caused me to have to relocate my turn signal(s). At first I tonight I could just see it to my parking lights. The hazard fuse kept popping under the hood though. So upon some research I found out that they perking light is a 7 watt filament and the turn signals are a 25 watt filament. So it wouldn't work. Then i read about all the 80's vehicles have a rear turn light assembly that usually take the 1157LL bulb with both the filaments handy.
. So the white/ black wire us ground. The green/ brown is hot. Test the connector to fund out What wire triggers what filament. connect the turn hot yo the 25 watt and the parking to the 7 watt. Viola.
. I used a drill to alter the corning light assembly so the connector would clamp down.
