Tips & Tricks Tips and tricks to make the site easier to use such as posting pictures, where to host them, and avatars
94 toyota pickup IFS LIFT
Old Mar 5, 2018 | 01:03 PM
Kadi96915's Avatar
Ok so im about to do a lift on my 94 toy. I made my own lift shackles for rear and i also got the 2 1/2 inch ifs lift kit. My question is after i install the front ifs lift do i need to reset my Caster and Camber and also my alinment? What do i need to have done after i install the frint ifs kit?
Old Mar 5, 2018 | 02:23 PM
Co_94_PU's Avatar
You don't say what kit you purchase or what was included, but yes you need an alignment done by a qualified person (understands the required adjustments for a lift) if it is a street vehicle.
I don't fully understand all these but for an example, ball joint spacers can alter the steering rotation angle (moves the center line) similar to changing wheel rim backspacing. (Typically the pivot point of steering if you run an imaginary line through it will be in the center of the tire tread. There is a second imaginary line from this steering angle that intersects the middle of the rear axel that the draglinks use..)
Bottom line yes, loosening anything in there except the anti sway bar pretty much means it needs an alignment.
shar
Aug 20, 2016 09:17 AM
4lowyota
Aug 6, 2014 04:25 PM
weigellj
Dec 22, 2006 12:20 PM
