Water in drivers side floorboard
1998 4runner; water accumlating on drivers side floorboard. Have checked the AC drain, removed cowling to check drains and windshield, checked heater core; all were okay. Water appears to be coming in from the outside somewhere,any suggestions.
There is a rubber grommet on the firewall near the brake booster under the hood where the wires come through. Have you made more holes in the grommet to pass extra wires through or anything? Check to see if it's installed properly. Take a garden hose and spray the grommet from the engine compartment side, and check to see if water is coming into the cab.
the above mentioned items are all possibilities. I would also check your door seal, sometimes they get compressed to the point it won't work. fix it so you don't end up with this on my driver's side:
found this after fixing a leaky windshield and pulling up my carpet.
Good luck..and welcome to Yotatech!
CT
WTB[WestCanada]: 1989 4runner stock front bumper and other items
lledwod
Aug 30, 2016 01:03 PM
crashburnoveride
Jul 10, 2015 06:39 AM
