Sponsored by: CARiD
valve adjustment for T100 do I need it?
Old Jul 21, 2011 | 02:34 PM
wolfpaw's Avatar
Question valve adjustment for T100 do I need it?
I have a 97 T100 with 161,000mi looking to repalce the intake and valve cover gaskets. Is there a valve adjustment to be done while I have all this stuff apart? If so where do I find the info to do this? thanks to anyone who can help!
Old Jul 21, 2011 | 02:45 PM
scuba's Avatar
Yes. The valves need adjusted every 60K miles.
http://www.ncttora.com/FSM/
Old Jul 21, 2011 | 04:01 PM
wolfpaw's Avatar
thanks, I never did one on any of my toyota, was wondering how complicated it is to do? and if I needed any special tools for the job
Old Jul 21, 2011 | 11:47 PM
wyoming9's Avatar
Smile
Yes while it says the valves should be adjusted I wonder how many unless the rockers are loosened or removed ever do it.
If you need to replace the valve cover gaskets it is a good time.
A feeler gauge of the correct sizes and you should already have what you need
Old Jul 22, 2011 | 04:35 PM
wolfpaw's Avatar
Smile
Thanks again I don't notice any noise from the valves, but since I'm tearing so much off to replace the gaskets its worth checking valves for the adjustments it may need.Thanks again for the help. I have never had to work on my Toyotas much so just making sure I do it correctly
Old Jul 22, 2011 | 05:08 PM
MudHippy's Avatar
Wrong engine. And you wouldn't adjust the valves with the rockers loosened or removed in any case.
Not too complicated to check the clearances with feeler gauges. But if they need adjusted, then it gets complicated in a hurry. You'll not only need special tools, you'll also need different sized replacement shims to make any clearance adjustments. IOW it's a PITA!
Old Jul 22, 2011 | 05:20 PM
scuba's Avatar
Don't need any special tools if you can pull 2 crank shafts.
YMMV.
Blamalam
Mar 12, 2022 07:34 AM
Dennisx2
Aug 10, 2015 06:48 AM
Dennisx2
Aug 4, 2015 01:26 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
razorman8669
Jul 12, 2015 12:13 PM
