Sponsored by: CARiD
Tire whistling...
Old Feb 15, 2013 | 07:21 PM
JeremyW94's Avatar
Tire whistling...
okay so I just got a 3 inch suspension for my 94 Toyota pickup, 4x4. 3"front 2" back. Ran fine and perfect no problems before the lift but after the lift once I hit about 20 mph my front left tire starts making the whistle noise, since the lift it has turned outward a bit as well, and it makes the ride a bit bumpy. I'm assuming I need to go get my truck realligned?
At least I think that's what will fix the problem, just making sure before I end up going to do that in the morning...
Old Feb 15, 2013 | 07:25 PM
BamaYota1's Avatar
I don't know about the whistling, but a full alignment after a lift is usually necessary. Only time I had a tire whistle was when it had a hole in it.
Old Feb 15, 2013 | 07:48 PM
JeremyW94's Avatar
I don't think its a hole because we didn't use anything that really could put a hole in it .. I can tell the tire Has shifted and I think its riding more closer to the sidewall and its just producing this annoying sound that reminds me of a whistle
Old Feb 16, 2013 | 10:14 PM
Co_94_PU's Avatar
Yeah any adjustments to the steering or ride height requires an alignment check. Not sure about the whistle, air stems with no caps catching air like a bottle?? Inspect for rubbing. whistling could be squeeling which would be rubbing.
1uzRunner
63
Nov 10, 2018 03:58 PM
Williamemslie
14
Oct 5, 2015 09:28 AM
AkitaDog
Sep 3, 2015 09:01 PM
128keaton
Sep 3, 2015 05:09 PM
matthew138
Sep 3, 2015 08:21 AM
