Timing Belt
Remove stuff that's in the way, remove bad belt, put on new belt, re-install previously mentioned parts. Easiest way.
You may want to put on a new water pump, and replace crank seal too.
Done. Your welcome.
Done. Your welcome.
http://www.4x4wire.com/toyota/maintenance/timing_belt/
Here is a good write up on another blog site. I used this for my 2003 Tacoma. Very extensive procedure. I wouldn't do it unless you're very comfortable with a lot of R&R.
Good luck
M3 Michel
Good luck
M3 Michel
