Sponsored by: CARiD
t-100 diff will not fit an 87 4runner
Old Jan 26, 2011 | 06:09 PM
polycrack's Avatar
can u put a t-100 rear diff on the 87 4runner? Does the t-100 also have a 8" rear end w the same gear ratio? if theres allready a build thread pls send me a link. tryed to search too much junk that has nothing to do w what im looking for
Old Jan 26, 2011 | 06:14 PM
pmoose's Avatar
I believe the T-100 had the same 8" diff as the minitrucks. the only difference was the design of the housing on the outside. I have a rear diff from a 1997 4runner in my '93 Pickup and supposedly the T-100 8" was the same as the 3rd gen 4runners so im pretty sure it will bolt up and work. It uses the v6 style gears
Old Jan 26, 2011 | 06:18 PM
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
No...
Old Jan 26, 2011 | 06:19 PM
Nimyad's Avatar
Ya that's a big N O on that swap, t100 uses an 8.4 diff with 10 mm bolts so ya
Old Jan 26, 2011 | 06:22 PM
Been there, tried that, got the hat, had to sell the truck, AND got butt hurt from Toyota when I realized () my V6 Hilux diff wouldn't fit, and called for a price of the T's rear gear...$900 IIRC.
Had factory 4:87's and I was too scared to get a A.M 4:88...
OOOUCH!
Old Jan 26, 2011 | 06:28 PM
Here, I'll do the work for you. Save this link to faves in case you have any other Toyota axle questions.
http://home.4x4wire.com/erik/diffs/#T100-Tundra
Old Jan 26, 2011 | 07:08 PM
polycrack's Avatar
I just want to swap the axle, all parts from the t-100 intact, to match the blazland LT kit in the front 3" on each side. I belive it's 6" total longer and should have the same wheel bolt pattern. I just need to match the gears for the 4x4. the e brake should be the same too i would think? and tabs are ez to weld
Old Jan 26, 2011 | 09:25 PM
Nimyad's Avatar
Oh then yes you can do that. Anything is possible lol, but shouldn't be that hard of a swap if your using the whole axle. Just probably new springs perches, redrill your axle flange (maybe) and match the gears. It'd be stronger then the 8 inch you have now too. As for the e-brake you'll have to extend the cable probably
jerusry
Oct 19, 2015 05:28 PM
Daneums
Aug 20, 2015 05:36 AM
andrewtexas123
Jul 14, 2015 04:29 AM
icentropy
Jul 9, 2015 02:12 PM
wilbertd
Jul 6, 2015 07:39 AM
