Sponsored by: CARiD
Swap 90 22re into 86 questions?
Old Oct 26, 2010 | 07:38 PM
sasknate's Avatar
Do I need to swap my EFI from my 86 pickup onto the 90 engine ,if I'm planning on dropping a 90 22re into my 86 which also had a 22re?? Would this all be plug and play??? Both trucks are auto's.Thanks!!
Old Oct 26, 2010 | 07:43 PM
xxxtreme22r's Avatar
as long as none of the sensors goes to the new truck yes it's a direct swap. You cannot use anything off the new engine electronic wise, including injectors, ecu, temp sensors etc etc.
Old Oct 26, 2010 | 08:16 PM
sasknate's Avatar
sorry i am a bit new to toyotas. My 86 has all existing wiring still in it, so if I was to swap in the 90 engine,I would need to use all 86 electronic parts existing in the truck and anything I can transfer to the 90 engine?....so no 90 electronics. .....just thought I'd clarify with you, thanks a lot for the response greatly appreciated.
Old Oct 26, 2010 | 08:19 PM
that's correct.
Old Oct 26, 2010 | 08:23 PM
this also goes for all of the vacuum sensors and emissions junk as well just to be safe.
mskalmus
May 28, 2017 07:51 AM
steve miller
Oct 10, 2015 01:40 AM
Coreyr384
Jul 10, 2015 11:13 AM
HRDC0R19
Jul 5, 2015 06:43 PM
