Sponsored by: CARiD
sink money into a ifs eliminator or sell out and get a sfa rig?
Old Dec 22, 2010 | 01:12 PM
bobby_duce's Avatar
Originally Posted by hunter h
yea im leaning towards the ifs for now just dont have the money and no i cant do the work myself. i think i could figure it out but i have no welder or torch so...
well you just made it alot easier to figure out what you should do. if you dont have the money and you cant do the work your self start off stock and get new things as you go. good tires go along way and are a good start point. lockers are great but alittle pricey but the best bang for your buck.
edit:
Old Dec 22, 2010 | 01:49 PM
tpaine14's Avatar
knowing big liftand big tires is not the answer is the first step! congrats youve just overcome the most difficult off road obstacle
Old Dec 22, 2010 | 02:13 PM
hunter h's Avatar
Yea I love following the big tires with 31's and going about anywhere they can go cuz with an open diff. Tires aren't a whole lot of difference. Pics later on tonight. Haven't gotten around to it
Old Dec 22, 2010 | 02:42 PM
AxleIke's Avatar
The solid axle truck will save you only the money of buying a used axle. You will still have to essentially do all of the same stuff that you would to your current rig to make the SA rig as strong and work as well as the IFS eliminator kit. A little less cutting, but almost the same amount of welding, and you also have to source an IFS steering box.
Old Dec 22, 2010 | 03:07 PM
  #25
hunter h's Avatar
What you mean source an ifs steering box
Old Dec 22, 2010 | 03:24 PM
  #26
AxleIke's Avatar
Solid axle trucks came with a push pull, or J-arm steering set up. Believe it or not, its actually weaker than the stock IFS steering. Most people opt to run high steer for strength and to keep the steering linkage up out of the rocks.
You can keep the SA mounts, but most people opt to cut them off, and replace them with virtually the same kit as the IFS Eliminator to benefit from the added flex, and the ability to move the front perches around to gain more wheel base, as well as push the axle forward to allow for better approach angles and fire wall clearance.
Old Dec 22, 2010 | 10:39 PM
  #27
hunter h's Avatar
Thanks. Yea I'm gonna run the ifs and build up everything else. Done with the sas idea for now
Old Dec 25, 2010 | 02:11 AM
  #28
Champ's Avatar
I had a 98 taco and I was in the same spot you are in. Granted I love the 1st gens but with that aside I looked at the price of swapping everything over and decided I would be better off selling outright. Looking back at it im not regretting it but by the time I fix all the mess ups from previous owners on my truck, I could of had the truck i owned since day one with a SAS under it for about the same price.
All I am sayin is dont let the initial expense throw you because your looking at going to a truck that is 20+ years old. There will be alot of things to replace. As far as your new IFS rig to a SAS you can pic up parts used or new and slowly build your rig.
Old Dec 25, 2010 | 06:16 AM
  #29
wd21_sr5's Avatar
Originally Posted by James Woods
What would you call an off road ricer?
Domestic driver... or mall terrain
Stick with the IFS, build as you go. If you want a SFA that bad you can collect needed things over time then do it down the road. Just enjoy what you got now though, and be suprised at what can be thrown at the IFS
Old Dec 25, 2010 | 02:32 PM
  #30
hunter h's Avatar
Yea I'm keeping it. It only has 60,000 on the motor don't wanna get something with alot of problems. Its in shop now replaces front seal. As soon as it gets out I'm locking front and rear, think with Aussie lockers
Old Dec 26, 2010 | 08:56 PM
  #31
hunter h's Avatar
well i say that have now heard that lockers dont do much in the muc so more researching first
Old Dec 26, 2010 | 10:00 PM
  #32
bobby_duce's Avatar
where did you hear that?
Old Dec 27, 2010 | 06:25 AM
  #33
Tech Tim's Avatar
Originally Posted by muddpigg
Wheel the IFS it will teach you more that any built wheeler. ....snip...... many on here have well built IFS rigs that are wheeled.
Well said right there.
Get a rear locker first, Aussie or other lunch box locker is your best bet on a budget.
Then go Blazeland low buck long travel. You won't believe the difference it will make and the price is better than a SAS kit.
Old Dec 27, 2010 | 08:20 AM
  #34
hunter h's Avatar
Just googled of they help and read around. That's what a few said. Thanks for the info guys. Haven't looked into a long travels kit yet
Old Dec 27, 2010 | 11:50 AM
  #35
bobby_duce's Avatar
well lockers are one of the better "first things to get". many yotatech memeber have said lockers, tires and sliders can get you alot of places and then get other things as you can.
Old Dec 27, 2010 | 12:18 PM
  #36
dropzone's Avatar
Fossilized
I am running aussies front and rear. If you DD your truck and have a need for 4WD on the road...don't lock the front unless you do an ARB or other selectable, they tend to pull straight and not allow you to go the direction you want
hmmm...they work well, if not they wouldn't be in as many trucks as they are
I love those guys, usually Jeeps. I love when I see a Cherokee with 4 pairs of off road lights, 38 inch tires, stickers all over it and on the stock Dana 35 and no off road permit any where. What would you call an off road ricer?
that is half the Cherokees in Washington County
Old Dec 27, 2010 | 05:56 PM
  #37
rattlewagon's Avatar
We call them "Mall Crawlers"
Old Dec 27, 2010 | 07:57 PM
  #38
hunter h's Avatar
Its not a daily driver but I do have to drive it to the trails being I have no way of towing it. Would an Automatic front locker be a bad idea for that.
Old Dec 27, 2010 | 09:21 PM
  #39
muddpigg's Avatar
You will be fine with an auto front locker. I had one with IFS and have one now with SAS. Mines a DD. If you shop around you can find front IFS axles locked and geared for a good price. You can look for the stock rear with 4:88s throw in a locker and boom. You set for when you decide to get bigger tires.
Old Dec 29, 2010 | 01:42 PM
  #40
hunter h's Avatar
Would it not be cheaper to just lock and gear my stocks instead of swapping axles
