reverse lights out
reverse lights out
I have a 91 4 runner and i recently replaced the clutch ,and after I got done putting everything back in my reverse lights don't work I made sure everything is hooked up right. I also changed the fuse and bulbs does anyone have an idea of what it could be?
If you don`t have a multimeter now is the time to buy one!!
Simple to check the switch put the transmission in reverse see if you have continuity across the pins on the switch.
This is where having a meter with the audible continuity signal maker it nice
You can also check for voltage coming into the switch.
in the course of doing the clutch is it possible the plug could have got dirt in or the pins could have got bent??
FS[PacNorWest]: Toyota Inclinometer/Altimeter
AkitaDog
Sep 1, 2015 08:05 AM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
Poncho0206
Jul 10, 2015 06:21 PM
madxman21
Jul 9, 2015 10:26 AM
