regaering my solid axle for my swap
Old 10-25-2012, 12:49 AM
ajetski07's Avatar
hey there I have a 1992 toyota extra cab that I will be doing a solid axle swap on, I already have a 5 inch lift on my truck and it has also been re-geared to 4.88 to match the lift and tires. So basically my question is if I can use the same 4.88 gears out of my IFS diff and out them inside the solid axle that I will be using? Or do i need to get a new gear set for this? Because I know that I can not run the stock gearing since my rear will already be re-geared. If any one can help me out with this i would be very greatful. Thanks guys
Old 10-25-2012, 06:02 AM
Baggedgmc1995's Avatar
Here this will help: http://www.pirate4x4.com/forum/toyot...faq-2-0-a.html
Old 10-25-2012, 06:04 AM
waskillywabbit's Avatar
IFS front diffs (7.5") and SFA front diffs (8") are completely different.
So no you can't use it.
:wabbit2:
Old 10-25-2012, 12:29 PM
ajetski07's Avatar
@waskillywabbit thanks for getting a response to me so fast, I was pretty sure that it would not be interchangable but I figured why not ask and make sure. Thanks again for the help.
Cheers
ajetski07
Flying91
45
04-11-2024 04:39 PM
gieselman
10-12-2015 01:34 PM
deepmarsh
08-06-2015 03:44 AM
Backcountry411
07-24-2015 08:06 AM
scottyg486
07-19-2015 05:34 PM
Quick Reply: regaering my solid axle for my swap
