Sponsored by: CARiD
rearend of my truck is "spooling" up or "winding" up
Old Jun 5, 2010 | 05:44 PM
Tank8265's Avatar
I have 4.5" of suspension lift and 35" tires with a 22re and 4.88 gears. When I accelerate it feels like the rearend of my truck is "spooling" up or "winding" up. I am not sure what is causing this and how to fix it?
Oh and it is a single cab pickup
Old Jun 5, 2010 | 05:52 PM
rattlewagon's Avatar
Spooling up? From this it sounds like a slipping clutch. Is this an auto or a 5 speed.
Old Jun 5, 2010 | 05:56 PM
Tank8265's Avatar
It is a 5 speed, Im pretty sure its not the clutch. Its getting plenty of power and its moving. It feels like the suspension is winding up or something. I had a pro Toyota shop put in a centerforce clutch.
Old Jun 5, 2010 | 06:08 PM
myyota85's Avatar
dont see that centerforce slipping. spooling up are u hard on the gas when it does it or just now and then.
Old Jun 5, 2010 | 06:43 PM
Tank8265's Avatar
I am not hard on the gas, and it does it all the time. every time you go from a dead stop. you will feel it stop once you get to about 10 mph
Old Jun 5, 2010 | 06:53 PM
Teuf's Avatar
Try and describe better the symptom, what is spooling up??????
Old Jun 5, 2010 | 07:02 PM
Tank8265's Avatar
It feels like the rear axle is rolling forward and compressing the suspension and then rolling back to normal and it kinda of makes it hop while it unswists. This is what I think is happening. I am not really sure.
Old Jun 5, 2010 | 07:07 PM
toyota4x4907's Avatar
Axle wrap.
Let me guess...lift blocks?
Old Jun 5, 2010 | 07:23 PM
Tank8265's Avatar
haha no, new leafs in rear and shocks. what is axle wrap?
Old Jun 5, 2010 | 07:25 PM
Teuf's Avatar
Ditto on that.
Old Jun 5, 2010 | 08:05 PM
hilandfrog's Avatar
U bolts plenty tight?
Were they checked after a few hundred miles again?
Repo
Old Jun 5, 2010 | 08:13 PM
Tank8265's Avatar
I am going to re-check everything tomorrow. Bolts, drive shaft, springs, grease. On big trucks they put the strut things from the center of the truck on the frame to the axle would that help?
Old Jun 5, 2010 | 08:22 PM
iamsuperbleeder's Avatar
Originally Posted by toyota4x4907
Axle wrap.
lol, 4.5" of blocks?
Old Jun 5, 2010 | 08:28 PM
Tank8265's Avatar
I know on full size trucks that if you grease the drive shaft slip joint that will be the source so I am going to try that as well.
Old Jun 5, 2010 | 08:31 PM
yotaman85's Avatar
your problem is 4.5" of lift, haha J/K..it is axle wrap for sure. get a nice anti-wrap bar and you'll be good..
Old Jun 5, 2010 | 08:43 PM
Tank8265's Avatar
After googlin axle wrap I understand what axle wrap is and what an anti wrap bar is. Are there any types or things that I want to make sure that it has? Wear and how do I want it to be mounted and does anybody have any experience with this on their rig?
Old Jun 5, 2010 | 08:50 PM
dude they make up to 6" blocks, if not larger.
Old Jun 5, 2010 | 08:52 PM
Tank8265's Avatar
but who would use them? Why would you use blocks period? Blocks= Problems!
Old Jun 6, 2010 | 05:36 AM
waskillywabbit's Avatar
Please use relevant titles to your threads in the future. It will help you get help faster.
Old Jun 6, 2010 | 06:22 AM
myyota85's Avatar
http://www.youtube.com/watch?v=t_z72zPCsJM
from 42-45 is axle wrap watch the rear axle.
