rear seal 22RE
rear seal 22RE
Hey guys, I'm replacing my real seal in my '90 2wd 5 spd 22re and I've never done it before. Anything I need to know going it to it? Things to do? not do? tricks to it all? Any input helps!
Welcome to Yotatech first off, Its not too hard a job if you have the tools, just check the crankshaft face where the seal rides and make sure its still smooth, if it is wore down severly then they make a sleeve to put overit I believe, good luck. IF you have questions, we'll be happy to help here.
jerusry
Oct 19, 2015 05:28 PM
22re, 31, cost, crankshaft, engine, installing, main, rear, repair, replacement, seal, toyota, yotatech
