Sponsored by: CARiD
Rear axle seal question
Old Apr 2, 2010 | 01:39 PM
SoloRunner's Avatar
I am getting ready to replace my outer rear axle seals, and re-do my brakes. The bearings don't make any noise at all. So, my question is, Since I am pulling it all apart anyways, should I go ahead and do new bearings, retainers, inner axle seals? That way everything is new. Or, should I just keep it cheap and simple by just doing the outer seals?
any opinion helps!
Old Apr 2, 2010 | 01:45 PM
Just Learning's Avatar
look at the bearings, ,heck i would - if you can afford it and want to keep the truck , i would replace them, for peace of mind, knowing thats the rear is done.
Old Apr 2, 2010 | 06:11 PM
myyota's Avatar
If your 4Runner has over 150.000 miles on it, replace the bearings, you will already have everything a part so its worth doing. My 86 4Runner has over 200.000 miles on it and when i pulled the rear axles to install my locker the bearings were so bad that i don`t even know what was holding them together.
Old Apr 10, 2010 | 03:05 AM
Ron Helmuth's Avatar
the inner axle seals are a weak spot on the 3rd gen Runners. You don't mention a mileage but they typically fail at 75-90K miles.
My drivers side rear was done 2x before the new and improved part number was recommended by Toyota. Final digit of the part number is a 6, I can probably get the whole number if needed but any of the local stealerships should know all about this also.
Toytec is local for your upcoming lift-personally I believe TRDPARTS4U.com has better pricing and saves sales tax.
Like that courtesy light mod you have going there
Old Apr 12, 2010 | 09:58 AM
SoloRunner's Avatar
all done
So we spent most of Saturday pulling apart the rear axle. replacing the seals, re-building the drum brakes and flushing the brake system. The Passenger side wasn't bad at all. but the driver's side was absolutely disgusting. I know that it is not done if there are no pictures, but we were on a time limit and I wasn't about to get the black sludge all over my camera. All in all it was a fun project, fairly simple. Drum brakes were the hardest part. Thanks to everyone's info and input. I love yotatech! This weekend I am attempting to conquer the timing belt, water pump and accessory belts....... then the week after that, OME lift. it has taken me a while, but she is comin along nicely.
Old Apr 28, 2010 | 07:43 PM
So stay in touch if you would consider doing this for others locally for parts or money or both.
For example- I still need my pass side axle seal done and would prefer to do it before trashing my rear brakes again. We held a lift day at my garage once before and I would host another if/when you are ready to do that. Several CO guys from Co4Lo and hanging out here and on T4R to meet and greet. For all I know you are one of them...
jerusry
Oct 19, 2015 05:28 PM
andrewtexas123
Jul 14, 2015 04:29 AM
Kalihi,HI
Jul 9, 2015 04:29 PM
87turboPA
Jul 9, 2015 05:58 AM
toyoda8488
Jul 5, 2015 10:18 PM
