Sponsored by: CARiD
primary differences between '00 and '01 TRD TACO?
Old Aug 6, 2007 | 07:58 PM
LuminoZ's Avatar
So i've been looking around for quite a while for a the right tacoma, and i'm trying to narrow things down. From what I've gathered the only real differences between the 2000 and 2001 are cosmetic. I.E. Grill and interior trim. I'm referring to SR5 TRD X-Cab trucks, so If anyone could let me know if there are any other major differences that would be great. I wasn't able to scare up any thing with the search...
Old Aug 6, 2007 | 08:03 PM
DeathCougar's Avatar
its all just cosmetic. Same engine, same basic trannys, rear ends, etc etc.
Old Aug 6, 2007 | 10:32 PM
LuminoZ's Avatar
sweet. thanks for the info.
Old Aug 6, 2007 | 11:47 PM
apalmer1's Avatar
there is a frame weakness in tacomas above the rear wheels where the rails slant up, it was suppost to be "fixed" after 00 for the facelifted tacos. Its still a problem for 01-04 but supposedly according to toyota not as bad as beforehand.
Old Aug 7, 2007 | 12:52 AM
rocket's Avatar
The front sway bar is also different. Disconnects don't exist for the '01+
Old Aug 7, 2007 | 05:07 PM
LuminoZ's Avatar
Is that weakness something that a little 1/4inch and a welder couldn't fix by boxing the frame? Or is it something that you really don't need to worry about.
Old Aug 9, 2007 | 01:54 AM
rocket's Avatar
It's a weakness (frame) thats NEEDS attention. Without reinforcements, I've personally seen the damage that will occur a couple times.
IMO, the best $90~ that can be spent on a Tacoma:
http://www.demello-offroad.com//cata...415af0fd7976ee
http://www.ultimateyota.com/smf/index.php?topic=2045.0
Old Aug 10, 2007 | 02:45 PM
LuminoZ's Avatar
I'll definitely get some of the DO frame braces... shouldn't be too hard to weld those buggers in. Just picked up an 02 TRD SR5 Xcab... other than the gray wire mod, anything else i need to do/ watch out for? I got a hook up with AEM so I'm not going to bother with the deckplate mod.
Old Aug 10, 2007 | 03:04 PM
Tacoclimber's Avatar
If the radio is the same as in my 03, when the radio is on, push and hold the audio control knob/button (the large one on the right hand side) until it beeps. Viola! You now have mid range adjustment, where previously, you could only adjust the bass and hi range. This setting will stay, as long as you shut the radio off before turning off the engine. If you turn the key to "off" without turning the radio off, you'll have to do the whole thing again. I hardly ever forget, anymore, and the sound difference was so noticeable that I decided to not get a new head unit and use the money for something else.
Talk about a cool free mod!
That and I disabled the piezo that beeps when you lock/unlock the doors. That always annoyed me...
Old Aug 10, 2007 | 03:29 PM
gabrielthetacoma's Avatar
up until 2001 the rear leafs were made out of a crapier steel. they started using better steel in 2001. I learned this the hard way.
Old Aug 12, 2007 | 08:35 AM
LuminoZ's Avatar
Good info for sure, going to try the stereo trick right now...
Taco where in AZ are you? I'm at NAU for mechanical enginnering right now...
sanctfy
All Other Toyota Swaps
Sep 15, 2015 02:52 PM
Crgrey42
Aug 10, 2015 04:23 AM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
Toyvana
Jul 29, 2015 10:47 PM
