Post mudding maintenance
went and romped it for awhile and got a little to comfortable with my friends how deep is this hole and sank in pretty good
so pretty much got really really stuck whole front end was underwater and a 6inch deep pool in corner of the truck turned it off before it started sucking water but i know something needs work after being in that for 6 hours any help would be great
check all of your diff fluids and trans fluid if your a manual trans for water. Pull your wheels and clear the mud out of the calipers and drums before it hardens.
if your cv boots are cracked there is a good chance to got water and mud in those as well.
hahahahahaaha a hole that size deserves to be checked for depth before you go through it.
make sure you dry out the inside of your truck so it doesn't rust.
just the normal diff fluids, tranny fluid, t-case fluid.
ok will do thanks for the info and he poked it with a stick and i took it as deep but not to bad but apparently it was like some misunderstanding wont have time to mess with it till monday though so its gonna harden up and make it more fun for later
coffey50
Jul 28, 2015 10:55 AM
scottyg486
Jul 19, 2015 05:34 PM
