Sponsored by: CARiD
Odometer not working
Old Jan 19, 2019 | 03:18 AM
Smogsucks's Avatar
So I've had two clusters, 81 pickup all stock engine and drivetrain wise anyway. On both the odometer did not work, but the speedometer worked just fine. (Only replaced the old one because the needle had broken off in the speedometer)
now ive looked around on this forum, and it seems to be pretty common for both the odometer and speedo to stop working, or just the speedo, but haven't found any the other way around
It's the only guage that isn't working. Any ideas?
Old Jan 19, 2019 | 05:10 PM
old87yota's Avatar
I have not opened up a 1981 gauge cluster before, but if it is like the later trucks, you may have some broken plastic gears and/or stuck digits in the odometer assembly.
If the speedometer works, then the speedometer cable is not broken.
You will probably have to open up the assemblies and inspect for broken or stuck parts.
Old Jan 19, 2019 | 05:15 PM
Smogsucks's Avatar
Yeah I was kinda thinking the same. Gonna grab the old one and crack it open so I don't break the one I actually use.
Maxwell4208
May 14, 2016 02:55 PM
mhoupt856
Oct 22, 2012 08:23 AM
axekick
Jun 13, 2012 06:41 PM
heebeha
Jun 20, 2007 04:25 PM
