Sponsored by: CARiD
Number 1 cylinder is DEAD!!!.
Old Nov 11, 2008 | 05:10 PM
axle09's Avatar
Ok. I have done some maintenance to my 22re and now my #1 cylinder is dead. I have fire coming from the distributor to the plug but it seems no fire in the cylinder. When I unplug the #1 spark plug wire, it does not change the way the engine runs. Please help I have no Idea what to do next.
Old Nov 11, 2008 | 05:41 PM
ROCK LIZARD's Avatar
"I have fire coming from the distributor to the plug but it seems no fire in the cylinder. When I unplug the #1 spark plug wire, it does not change the way the engine runs."
Did you replace spark plugs when you did maintenance? You could have a bad sparkplug--it happens even with new plugs. Try a different plug in that cylinder.
Old Nov 11, 2008 | 06:11 PM
Yodaforce's Avatar
Does the exhaust manifold get hot by #1? Compression check? Did you pull any other plugs while running to verify? How does the plug look? Compared to the others. How do you know it is getting fire "to the plug" but not in the cylinder?
How did this problem start? Retrace your steps to the start of the problem.
Old Nov 11, 2008 | 06:15 PM
jason191918's Avatar
Did you gap the plugs? Pull the plug, ground it, and turn over. Does that one fire? (Unplug the rest of the plugs so they don't fire)
Old Nov 12, 2008 | 08:45 AM
axle09's Avatar
ok. I did change the plug with the one in cylinder 2. after a restart it didnt change. I also unplugged the #2 #3 and #4 wires one at a time to see the difference. Every one made a difference in how the engine ran. But when I take #1 off, no change. I dont think it would be compression because I just had the engine rebuilt with new rings and pistons. Also by looking at all the plugs i can tell they are all burning hot before i did the maintenance. So whats goin on here?
Old Nov 12, 2008 | 06:36 PM
Did you read my post?
Old Nov 13, 2008 | 03:53 AM
axle09's Avatar
yeah i read it. I just havent had a chance to get back on the truck to do some more test. I really appreciate all the input.
Old Nov 13, 2008 | 04:12 AM
pineapple's Avatar
Years ago my son's Nissan was doing the same thing (different cylinder) and I found it to be a faulty injector.
Old Nov 14, 2008 | 04:36 AM
axle09's Avatar
man you all know whats funny. I had to replace the o-rings on my injectors and had the whole plennem and manifold torn down. So I think that I might have actually plugged in the wrong clip for the injector.....hmmm.
Old Nov 26, 2008 | 03:48 AM
axle09's Avatar
Yep It was a faulty fuel injector. Runs great now.
pplusent
Sep 18, 2018 10:02 PM
raptor510
Feb 17, 2017 07:11 AM
Alex Bessinger
Aug 31, 2015 09:17 AM
Yotadawgjr
10
Aug 23, 2015 10:51 AM
raptor510
Aug 19, 2015 02:15 PM
