Sponsored by: CARiD
now a 22re with issues
Old Mar 17, 2009 | 08:10 AM
b/s rules's Avatar
i did the 22r to re conversion, evrything is hooked up and working, but the engine is surging between 2k and 3k rpms. if it gets lower than that it just dies. any help would be "pre-shaded".
Old Mar 17, 2009 | 08:55 AM
DeathCougar's Avatar
TPS adjusted correctly? Or even hooked up? Or perhaps the TPS is bad.
Bad thermal temp sensor?
Its pretty tough to determine what would be wrong over the internet, especially given that you just did a conversion. I could list every electronic componet as a "possible" cause, but what you really need to do is get a multi-meter and start testing things.
Old Mar 17, 2009 | 10:27 AM
b/s rules's Avatar
yeah i understand the internet thing. the tps is hooked up but if i unhook it while its surging, it will rev up to about 3500rpms and stay there steady. i don't know exactly how to adjust the tps. the only thing that is not hooked up is knock sensor and it's going on today.
Old Jun 22, 2009 | 03:51 PM
neub211's Avatar
If you figure it out let me know. I'm having the same problem as you after I changed out the timing set and head gasket. nThanks
Shane
shaneneuberger@hotmail.com
bigjstang
Jun 2, 2025 03:56 PM
MO transplant
Apr 23, 2023 11:58 AM
mskalmus
May 28, 2017 07:51 AM
montanatruck
Feb 26, 2017 07:07 AM
PlayAwhile
Jul 20, 2015 11:36 AM
