Sponsored by: CARiD
No power, misfire, 99 3.4l Tacoma
Old Dec 13, 2015 | 06:55 AM
Malikbrown's Avatar
Angry No power, misfire, 99 3.4l Tacoma
I have a 1999 3.4 6 cyl toyota tacoma and it says i have a misfire on cylinders 2 and 6 i changed the ignition coil and didnt help any. I have no power when i take of and it runs about 3500 rpms going 75 mph, it shakes bad when i deaclerate what could be the problem?
Old Dec 13, 2015 | 07:24 AM
Malcolm99's Avatar
Your probably better to start your own thread then resurrecting an 11 year old thread, unless you took your truck to the same guy li_runner did or performed the same tune up.
Your RPM's at 75mph shouldn't change ever it will always be 3500RPM in that gear at that speed. Start with plugs & wires & boots inspection/replacement paying close attention to #2 & #6 and do a compression test and let us know if anything comes up in a new thread. #5 Coil supplies power to #2 cyl, & #3 Coil Supplies power to #6, be sure to check all the connections between them and insure the wires are connected to the correct plug, you may have mixed up #2 & #6 wires.
Old Dec 13, 2015 | 08:12 AM
rworegon's Avatar
OP, created a new thread for you.
Welcome to YT.
Old Dec 13, 2015 | 01:14 PM
wyoming9's Avatar
Red face
Remember it can be any where in the circuit from the ECM any of the wires the spark plugs
You changed the coil ??
What do those plugs look like ??
Reading the plugs can tell you more of what is going on with those two cylinders .
Old Jan 1, 2016 | 08:09 PM
75w90mantraN's Avatar
x2 on checking the plugs. Tell more about what's been replaced, how long ago, CEL codes if any, that sort of thing. Switch out the coil on the misfiring cylinder with one from a good cylinder and see if that affects the misfire to rule out a bad coil. Good luck!
shooter86314
Jan 7, 2016 07:05 AM
Whitemoneypit
20
Nov 1, 2015 10:20 AM
jodyyota
Oct 10, 2015 03:57 PM
LCE_Performance
Oct 1, 2015 01:03 PM
