Sponsored by: CARiD
NEWBIE rear axle seal leaking
Old Jun 2, 2010 | 03:24 PM
1993hiluxsr5's Avatar
Originally Posted by xxxtreme22r
subscribed, just noticed mine is leaking too. grrr......
Try this method, its definatly worth it !
http://www.4x4wire.com/toyota/mainte...wheel_bearing/
Old Jun 2, 2010 | 05:16 PM
PismoJoe's Avatar
Wait, your shop wanted $500 to pop out the bearing and replace it, or to do the whole job?
I don't think you have to replace the bearing, gnarly, but its one of those things where you just feel better knowing its all been done
Old Jun 2, 2010 | 06:18 PM
no they wanted $500 for the whole job, and i replced the bearing aswell becuase when i took it all apart i found that the old bearing was stupidly lose and wobbly so i figuerd i might as well replace that seeing as i already had it all apart
Old Jun 2, 2010 | 10:14 PM
dark_fairytales's Avatar
good to see you succeed. i told you, you would wonder why they want to charge 500 for something pretty simple.
glad to help out man
Old Jun 3, 2010 | 12:00 AM
  #25
haha yeah, thankyou so much for your help
Old Jun 3, 2010 | 08:33 AM
  #26
PismoJoe's Avatar
Nice! I replaced mine as well, I didn't want to have to dig into my axle again for a while! Good work man!
Old Jun 3, 2010 | 11:56 AM
  #27
TOYOTA 1's Avatar
allot of times what happens is that, the axle seal goes bad and it allows gear oil into the bearing. the oil ends up flushing all the grease out of the bearing, no grease = a bad bearing. so like said above, its usually a good idea to change them both while your in there.
glad you got it done!
Old Jun 4, 2010 | 02:02 PM
  #28
Lysmachia's Avatar
Yup subscribed to this thread. Troy and I sometimes have access to presses, but many don't and I will refer them to this info here!
Old Feb 18, 2011 | 07:46 AM
  #29
jeffe's Avatar
Mine is leaking also. I'm going to do this this weekend. Inner seal, outer seal, bearings...What else will I be needing from the auto parts store?
Old Feb 19, 2011 | 04:20 PM
  #30
Lysmachia's Avatar
You'll need some moly grease to pack the bearings with....
jerusry
Oct 19, 2015 05:28 PM
andrewtexas123
Jul 14, 2015 04:29 AM
jakebarrett
Jul 10, 2015 07:15 PM
Kalihi,HI
Jul 9, 2015 04:29 PM
toyoda8488
Jul 5, 2015 10:18 PM
