Sponsored by: CARiD
Newbie question.. I have an few leaks that I'm trying to track down. *pictures*
Old Oct 18, 2007 | 01:03 PM
Billy_Baldwin's Avatar
Hey Guy/Gals.. i have a few leaks I'm trying to track down.. it appears that one is coming from a gold looking object on the drivers side motor near the oil filter.. and the other is coming from what looks to be the power steering pump or some place near it.. if someone could help me out that would be great! if there are some other common places to look please let me know!
Thanks
Billy
Pictures of the gold object
pictures of the power steering
Old Oct 18, 2007 | 01:13 PM
Ooh yeah its a 1990 3.0 4runner
Old Oct 18, 2007 | 01:33 PM
ozziesironmanoffroad's Avatar
check the hoses, check all connections, fasteners, etc. maybe your ps pump or oil pump gasket ruptured. or hell, check your oil filter, are you sure you have it tight enough?
Old Oct 18, 2007 | 03:00 PM
eric-the-red's Avatar
That 'gold looking object' is the oil cooler, a very well known spot for leaks on the 3.0. It has a large O-ring behind it that gets hard and tends to leak. It's very cheap to replace the O-ring, but a bit of a pita to get off and on due to the lack of room. There is a diagram in this thread
https://www.yotatech.com/forums/f116...art-id-111493/
Old Oct 18, 2007 | 03:07 PM
Thanks guys thats a lot of help! where can i get these o rings? and what is the best way to remove the oil cooler?
Thanks
Billy
Old Oct 18, 2007 | 06:35 PM
GSGALLANT's Avatar
Get the o-rings at the dealership. For your power steering pump, it typically leaks at the very back of it, or at the o-ring that seals the reservoir to the pump. you can get a rebuild kit that has everything you need to replace all the o-rings and seals in the power steering pump to make it "good as new".
Old Oct 18, 2007 | 06:45 PM
Get the O-rinng and seals at a dealer, I think mine was less than $20 for them all, though that was a few years ago. As for removing it I think I went through the driver side wheel well. There is only one large bolt in the middle, which is actually hollow and is used to feed oil into the cooler. Mine was very tight. There are also 2 coolant hoses on the cooler, they can be a bit of a pain to remove due to the limited room. You will spill a bit of coolant, but if you clamp the hoses it's not too bad.
If you'e due for coolant replacemnet it's a good time to drain the system and add new antifreeze.
Blamalam
Mar 12, 2022 07:34 AM
Eggslinger
Jun 8, 2019 03:32 PM
RaginAsian91
Engine Swaps
Mar 30, 2019 09:17 AM
jasonty
41
Dec 23, 2018 01:00 PM
terminator
Jul 27, 2015 07:13 PM
