Sponsored by: CARiD
NEWBIE front shock bolt stuck in bracket
Old May 29, 2010 | 11:48 AM
Camach's Avatar
I'm in the process of replacing my shocks all around. The backs were a breeze but now I'm stuck on the fronts. On both fronts the bolts seem to be fused with the rubber bushings. I've tried pounding them out but the shock bracket starts to bend.
Does anyone have any idea how to deal with this?
Old May 29, 2010 | 11:57 AM
Romans117's Avatar
Two or three things you can do. One impact wrench. Two torch. Three use a cole chisel to cut the shock eyelet and then cut the rubber bushing out and then chisel the sleave off the bolt. I have been there my friend!
Old May 29, 2010 | 12:05 PM
Camach's Avatar
No torch. My impact doesn't want to pull the bolt out it just spins it. I'll look into cutting the shock eyelet.
Thanks for the quick reply.
Old May 29, 2010 | 12:09 PM
Brian Pearson's Avatar
when your spinning the bolt with your impact spray some wd40 or something in there and pound it out with a hammer
Old May 29, 2010 | 12:34 PM
scuba's Avatar
Hit it with yer purse!!
Old May 29, 2010 | 12:37 PM
Romans117's Avatar
I agree Brian. That worked on one of them. The other needed the cole chisel. I tried vise grips on the sleave and spinning the bolt, but couldn't get it to work. The shock brackets held up with all the beating.
kazuya2416
Apr 5, 2024 02:17 AM
Sep 4, 2015 09:27 AM
msane99
Jul 17, 2015 10:13 AM
jon.r
Jul 11, 2015 03:34 PM
ItsJustD
Jul 7, 2015 07:49 AM
