Sponsored by: CARiD
New guy needs input
Old Nov 4, 2006 | 06:26 PM
DesertDweller's Avatar
New guy needs input
Hello all!
My wife and I have an '05 4Runner SR5 4WD. As my user name suggests, we like to go out into the desert, particularly to places you can't get in a passenger car. We don't do anything radical, and stick to established "roads" and washes that have obviously been traveled.
So far, the 4Runner is completely stock, and we're considering some very minor modifications. We've scraped the skid plates a couple of times, and are thinking either a little more clearance or a little less bounce might be nice. Oh, it came with the 17 inch wheels.
So, without getting radical and keeping our use in mind, what would you suggest?
Old Nov 4, 2006 | 07:57 PM
Elton's Avatar
welcome to yotatech... do you have the Xreas suspension ?
Old Nov 5, 2006 | 06:48 AM
Uh, hmm, er, um...
I don't know! How would I figure that out? I guess my prepurchase research wasn't as thorough as I thought...
Old Nov 5, 2006 | 10:12 AM
Paul H.'s Avatar
The XREAS comes standard on sport models and optional on the limiteds. If you have the base SR5 model you do not have it. A mild lift with slightly bigger tires is probably what you would want.
Old Nov 5, 2006 | 12:53 PM
Good Times's Avatar
you can start by reading this thread:
https://www.yotatech.com/forums/f117/modifications-accessories-faq-4th-gen-4runner-95442/
good luck!
edit:
that should keep you busy for some time. if you have any additional questions, feel free to ask.
welcome aboard!
Old Nov 6, 2006 | 05:06 PM
Tucson T4R's Avatar
I spend a lot of my time in the desert around Tucson. The biggest bang for the buck in my oppinion was installing the 3" OME lift and the largest tire that still fit in the spare tire hanger. I've gone a little nuts on additional mods since then but if you install a 3" lift and get more aggressive offroad tires, you will be happy on 90% of the well traveled back roads.
Old Nov 7, 2006 | 06:29 PM
Thanks for the input. We're leaning toward a coil and shock lift, maybe some better tires, and possibly some armor.
With a coil and shock lift does anything else need to be changed? Any problems with steering, brakes, transmission, etc.?
Old Nov 7, 2006 | 08:59 PM
Good Times's Avatar
hey rookie, did u get a chance to read the faq? that faq is comprehensive in that it should state every item needed for each modification. If it is not listed it is not needed.
good luck
Old Nov 8, 2006 | 11:27 AM
I did read it - great info. It is because of info there that we are leaning toward coils and shocks first. My guess was that it would have said if anything else was needed, but I wanted to be sure.
Old Nov 8, 2006 | 11:47 AM
Tucson T4R's Avatar
Going with the OME Springs and Shocks, nothing else is required. Just get a fresh alignment after installing the lift. Your idea of additional body armor sounds like a good second step.
Even when you install larger tires you won't have to do anything. By only going up to a 265/70/17 size (close to 32") you can use your spare tire storage area and the gearing is not effected enough to notice the difference.
Old Nov 15, 2006 | 04:35 PM
hamiltonj2w1's Avatar
I have been looking at lifts and can't decide which one to purchase. The ome medium duty springs or the complete toytec lift 3in front and 2in rear. I am curantly running 265 70 17 nitto tera grapplers. I am worried that the toytec lift will raise the front to much and it will sit to high. Has anybody installed this kit on there 4th gen yet? Any help on this would be greatly apprecated thanks
coleypull15
Nov 3, 2015 07:41 AM
coffey50
Jul 28, 2015 10:55 AM
dinks07
Jul 15, 2015 05:34 PM
ryerye13
Jul 14, 2015 08:27 AM
timmJ
Jul 7, 2015 02:01 PM
