Sponsored by: CARiD
Need T100 Diagnosis Help:Stuttering on Accelration and around turns
Old May 14, 2014 | 03:11 PM
rsiomkos's Avatar
I have a toyota 1996 T100. It stutters when I step on the gas and around turns...It has 255K mles on it. Was running fine this is recent development. Never having changed the fule pump I went ahead and did this and the fuel filter. No change. I noticed today that when the stuttering happens by stepping on the gas, if I puch in the clutch the engine revs fine with no stutter, re enguage the clutch and stuttering starts again.....However when Im just driving easy I do not notice any RPM climb or any true sign of a clutch failure......In terms of miles this clutch has 155K on it so it could very well be time....Any thoughts ?
Rob
Old May 18, 2016 | 04:00 PM
djohn24's Avatar
rsiomkos, did you ever find out what the issue was?
Old May 19, 2016 | 04:49 AM
rsiomkos's Avatar
Yes I found the issue
The issue I was having was due to an ignition coil, the spring portion that contacts the spark plug was intermittent...Actually the fix was just to squeeze the spring and snug up the connection....The spring is in the ignition coil rubber boot...So you need to look in there...
Regards,
Rob
Old May 19, 2016 | 12:14 PM
djohn24's Avatar
Ok, Thank you! I will post back and update if that was my issue or not.
jashoeuh
Nov 18, 2024 08:08 AM
rustym
Aug 7, 2015 10:39 AM
TDonkey
Jul 26, 2015 10:14 AM
rushw
Jul 18, 2015 01:46 PM
jgwerth
Jul 16, 2015 03:23 PM
