Need info/advice 88 pickup 22RE
Need to know what to look into.. Was driving home from work and it just died will not start at all Ive been driving it with no issues for about a year and a half now So I had it towed home :-(
Im new to RE engines so dont know know where to start diagnosing the problem I can only think fuel pump has quit or could it be something simple IDK
I have checked everything I can think of other than a shot in the dark start buying parts any quick way to diagnose what has happened
Again Its a 88 Pickup 22RE nonturbo
Any info would be greatly appreciated
Thanks
CR
Thanks
CR
EFI fuse in the block in the cab, by your kick panel is okay?
O2 sensor wire isn't shorting out around the transmission?
Fuses / fusible links in the panel under the hood all good?
Battery connections good, clean and tight?
Checked everything I could think of all looked good
My kick panel didnt have a cover so I didnt know which one was which But will try that out !!! It did have one blown fuse but I thought it was my aux lights It may just be it [Hopefully]
Thanks much
Thanks much
Try the fuel pump test jumper:
- http://www.4crawler.com/4x4/CheapTri...shtml#FuelPump
Sorry for putting the thread in the wrong forum
Thanks for the advice and the link very helpful
It was the [EFI] relay fuse Sorry for sounding like a noob But im new to this fuel injection stuff and didnt know where to start many thanks
Cheers
Cheers
Sep 4, 2015 09:27 AM
