Sponsored by: CARiD
need help on tire size!
Old Sep 15, 2009 | 01:59 PM
stereoguy's Avatar
Talking need help on tire size 86 4runner
i have a 86 4runner im slowly building up. it has a 4cyl 22re 5spd i have a old man emu spring tosion lift now have ball joint spacers and longer shackles too. I am currently running procomp x terrain 31/12.50/15 on 10" rims and would like to run bigger tires i know i can fit 33"s on but would like to do sas in future. Can i run 35's on this lift cause i want to buy tires only once . I dont mind cutting alittle on fenders i already have cut out flares from bushwacker on and i dont mind a small body lift too. If i can go 35's i will do gearing and lockrights in diffs and maybe a dual case and a twinstick this winter then as i can afford it a sas last. thanks for any help
Last edited by stereoguy; Sep 15, 2009 at 02:04 PM. Reason: no year model in title
Old Sep 16, 2009 | 10:26 PM
bigarms23's Avatar
i add a 1inch bl for the time being or put on the 35s and possibly trim the fenders and wheel wells thats if you dont want the bl
Old Sep 16, 2009 | 10:37 PM
Rusty Boots's Avatar
It should work, but you may or may not need to modify the firewall. I would try without the bl first just to save you some money, and if you feel you need it after that, then get it.
Old Sep 17, 2009 | 05:45 AM
stereoguy's Avatar
thanks for the answers. this site rocks! I am probably going to buy 35/14.50 15 boggers but i didnt want the 4runner to suck offroad just to get the bigger tires on. If i have to I'll stay with 33" but would like to know the main problems with running 35's on the 4cyl and drivetrain with the ifs.I had a 86 just like this in the past with 33's and liked it alot but now it seems like everyone is going the biggest tire least lift combo on the trucks and it's alittle confusing some input from you guys that have done this already would be great.
Old Sep 17, 2009 | 06:19 AM
xjdubber's Avatar
biggest tire least lift = best road manners not as tipsy. low center of gravity
djpg2000
Nov 11, 2020 04:56 AM
jgallo1
Oct 26, 2015 06:39 PM
Gravel Maker
RuffStuff
Aug 6, 2015 04:27 PM
Luvmeye22re
Aug 4, 2015 03:53 PM
coffey50
Jul 28, 2015 10:55 AM
