Sponsored by: CARiD
Need help locating rear hatch courteousy switch/pin
Old Mar 27, 2006 | 04:39 PM
Jdizzydub's Avatar
Unhappy Need help locating rear hatch courteousy switch/pin
I have a 97'runner and my rear dome light won't come on when the hatch is open and switch is on the door pos.The bulb is fine cus it works in the on position.My alarm is wired thru the door pins and dome light and I can't seem to find it-maybe in the lock?? I've read other similar posts and also tried past remidies(clean light with elec contact cleaner/silicone lube lock mechanism)and still no dice.The guys at Toyota(5 places) have no clue and were of no help..Any ideas? Thanks ya'll!
Old Mar 27, 2006 | 05:20 PM
eric-the-red's Avatar
The manual for my 2001 4Runner shows it inside the liftgate, I'm guessing it's a mercury tilt switch. I would think a 97 would be the same.
Old Mar 27, 2006 | 07:07 PM
dibble9012's Avatar
It is not a tilt switch, out of curiosity I searched for it one day, it is connected to the latch mechanism somehow, if you close the latch with a screwdriver the light will go off no matter what position the tailgate is in. The light is controlled by the rear door window relay (that relay box controls the wiper/dome light/keyless entry/rear window/defrost, and probably other stuff too that I cannot think of, lol. Hope that helps in your search for a solution.
Old Mar 27, 2006 | 09:23 PM
Jdizzydub's Avatar
Thanks dibble I really appreciate the insight. It all seems to make more sense now..I'll check it out first thing in the morning and see if I can either remedy the relay or just replace it.
88sasturbotoy
Jan 30, 2026 01:57 PM
gieselman
Oct 12, 2015 01:34 PM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
jetspeedz
Jul 13, 2015 09:32 PM
akaphilly
Jul 9, 2015 02:18 PM
