Sponsored by: CARiD
Nasty noise with 4WD disengaged, engaged=no noise
Old Feb 21, 2015 | 03:34 AM
Rafterman191's Avatar
Yesterday driving home in my '93 4Runner, there developed a noise like it was coming from front passenger side wheel. Chunking, clunking, grinding type noise. I engage 4WD and it goes away. I disengaged 4WD and it immediately returned. There has been a lot of snow/ice accumulation and cold as heck outside.
Old Feb 21, 2015 | 06:01 AM
thefishguy77's Avatar
Crawl under it and take a look. Might have to pull the hub apart but I would crawl under a poor for freshly broken metal. CV axle? Front drive shaft? Might be worth changing the front diff fluid. If you do that just make sure you remove the fill plug before the drain plug. If you do this check for metal in the used fluid. A drain and fill is very easy. Just sucks to do in cold weather.
Old Feb 21, 2015 | 09:37 AM
I took it out for some OTR diagnosis and realize it is not even engaging in 4WD, just the indication light on dash is showing that it is. Still when the 4wd shifter is in the 4wd hi or low the noise is gone. Damn shame.
Old Feb 21, 2015 | 10:34 AM
Check to see what your t-case fluid looks and smells like.
Old Feb 21, 2015 | 01:21 PM
Pulled it into the portable garage and the CV boot is torn, a round chunk of metal fell out when I pried off the boot.
Old Feb 21, 2015 | 06:48 PM
Sounds like you got lucky. Just a new cv axle. Around $100 I I remember. While your at it maybe look in to the mod that you press/hammer the studs out of the diff flange and replace them with bolts. Quick search for CV axle replacement should pull that thread up. Good luck. Glad you found what appears to be the problem.
Old Feb 21, 2015 | 07:36 PM
Thanks, should be cake.
norcal98
Aug 10, 2015 06:20 AM
genuinegemini
Aug 3, 2015 04:56 PM
Athansinis
Jul 27, 2015 08:38 AM
ripp96
Jul 25, 2015 02:32 PM
jgwerth
Jul 16, 2015 03:23 PM
