Sponsored by: CARiD
Muffler questions 1996 4runner
Old Sep 18, 2006 | 08:08 PM
chadbobb's Avatar
Ok, first off a friend of mine recommneded i get an IMCO. He said its the same thing as flowmaster, but cheaper.
I told my friend i want a nice deep tone, but not to be too excesivly loud. Would this be a good choice.
Also what is the stock pipe size for a v6 96 4runner? What should I go to? Also do i need to go from the cat back or is from the cat to the muffler enough?
I want a deep tone, but at the same time i don't want to be one of those guys with a f350 driving down the road going RRRRIIIIOOOOAAAR ROOOOAAAR. Being louder is fine, but being annoying is just, well annoying. Im sure you guys know what i mean
Old Sep 18, 2006 | 09:15 PM
Elton's Avatar
i really love my 18'' magnaflow muffler it sounds awsome its kindda loud but not like those ricers its has a real deep sound to it ..... also stock exhaust size is 2.25'' i would recomend you first do the deckplate mod and the isr mod first if you already havint heres the muffler you need muffler
i also got a sweet tip tip
also cost me about $70 bucks installed and it was no hack job
Old Sep 18, 2006 | 09:29 PM
Elton's Avatar
if your exhaust pipes are in good shape just replace the muffler its self .... if you didint live so far away i would let you sample what mine sounds like .... also wouldint hurt to put in ur location
Old Sep 19, 2006 | 09:49 AM
chadbobb's Avatar
is that the end of the exhaust? Because i see that the end is streched out.
I think i can get a new pipe and a new muffler for under $200 but if i don't need the pipe i won't worry about it. I just thought it might increase power a little bit... but then if the pipe behind the catylic is small i don't know if it would help unless i got a new cat also.
Old Sep 19, 2006 | 03:11 PM
Elton's Avatar
dont worry about that just have the old muffler cut of and have the magnaflow welded on use the stuff i posted .... also the end of the tailpipe is flared out to 2.5''
Old Sep 19, 2006 | 08:11 PM
chadbobb's Avatar
This isn't going to be really loud is it? You recomend the magnaflow? Im not doing the work btw. Im gonna take it to a shop and have them weld it in.
Old Sep 19, 2006 | 08:38 PM
Elton's Avatar
well not sure how loud it would be for you but its not look at me loud it has a real nice tone to it heres a sample http://pnw4runners.com/exhaust/exhaust.htm those aint the best but i might be able to get a clip of mine some time
Old Sep 22, 2006 | 08:25 PM
Elton's Avatar
have you deiced on anything yet ?
Old Sep 22, 2006 | 08:56 PM
chadbobb's Avatar
Im still thinking. Do you think i should go magnaflow over imco or flowmaster?
And what kind of performance increase am I gonna get from that magnaflow and what would i get if i change my pipe out?
Old Sep 22, 2006 | 09:01 PM
Elton's Avatar
magnaflow rocks perfomance increase is not going to be huge but will notice it a lilttle bit and my gas mileage has went up around a mile or too use the stock pipe as its fine for a none s/c motor also you done the deckplate mod and the isr mod yet ? .... i well say it did ahelp with acceleration i can now get up to 60 easy in 4th it pulls pretty good to also i can gain speed uphill now in 5th and hold it steady at 65
Old Sep 25, 2006 | 03:41 PM
chadbobb's Avatar
ok. I haven't done those mods yet. I probably will soon as i get more time to. I just did a tranny cooler install last weekend, and am working on some stuff for my alarm (chirper went out, and glass sensor doesn't work)
Within the month im gonna try to the deckplate, don't even know what the ISR is though.
BTW what is a s/c motor
Old Sep 25, 2006 | 04:26 PM
Elton's Avatar
isr mod https://www.yotatech.com/forums/f130/intake-silencer-removal-mod-installation-96-97-3-4l-engines-74837/ also s/c is supercharged
Old Sep 27, 2006 | 03:39 PM
Elton's Avatar
heres a short video not there very best ill get a better one later watch the first 20secs and then skip to 53 secs what i have done is the deckplate mod intake tube stock 2.25'' pipe with a 18'' magnaflow muffler and a stainless 3'' tip http://s63.photobucket.com/albums/h1...gAnch=imgAnch1
Old Sep 30, 2006 | 07:46 AM
chadbobb's Avatar
Oh, ic. Only get that tube if i don't want to do the ISR mod?
That sounds much better. I don't mind doing the ISR Mod. Which would give me more preformance? the air intake or the ISR mod with the deckplate mod
Old Sep 30, 2006 | 01:12 PM
Elton's Avatar
also was that exhaust to loud for you ??..... heres what i was talking about useing pvc pipe https://www.yotatech.com/forums/show...hlight=isr+mod
Old Sep 30, 2006 | 01:43 PM
chadbobb's Avatar
No, that wasn't too loud. It was right on the edge of being too loud though. It sounds good.
Old Oct 4, 2006 | 07:44 PM
chadbobb's Avatar
Ive got one question for you... when your just cruising, not really accelerating much, and at a constant like 1500-1900 RPM how loud is it? Can you hear it really well in the cab? How loud is my stereo going to have to be to drowned it out?
Old Oct 4, 2006 | 11:47 PM
Elton's Avatar
i drive around with the back window down and both front windows down and its not to loud inside but you can hear it and i have the volume on my stereo at like 18 and you cant here the exhaust any more
Old Oct 5, 2006 | 01:44 PM
Cliff96SR5's Avatar
What about JBA's EVOL?? Has anyone tried that?? Looks good. Anyone have a sound clip of that?
Old Oct 6, 2006 | 05:59 PM
chadbobb's Avatar
Just did the ISR and deckplate mod. Sounds A LOT better. I wasn't expecting those kinds of results.
