i have a stock 1993 pickup.i have 32x10.50x16 on it now but would like 33's im just not to sure if they would fit without rubbin....i would like a mud terrain tire but if i have to then ill go with an all terrain....oh, and if you are runnin 33's on a stock rig pictures would REALLY be appreciated...
now i know im going to be told to search, but i already have searched and i cant come up with anything....
thanks in advance
thanks in advance
nub.
1.5" coil spacers in rear and a slight torsion crank can get you 33x1250s, minimal rub
you need stock offset though, they cant stick out at all.
i have 33x1250, only rub the frame a bit in the rear... plan to fix that soon though
thanks so much..so 33x12.50 WILL work, the only problem is, i dont have coils in the rear, i have leafs..i think ima just get a 2 in. body lift and call it done...
who makes the 32 10 fiddys you have? id like to have some of them on mine. but they probably only make them for 16inch rims
Quote:
i have firestone transforce A/T...there more of a street tire than an all terrain though...thats why i was wanting to get somethin else....Originally Posted by yoder519
i have 33/12.5r15 swampers no lift all stock and it only rubs when you turn real sharp and when you hit big bumps when turned
Quote:
can you post some pics?Originally Posted by gentry20
