Sponsored by: CARiD
Manual Gearbox 88 pickup
Old Jun 13, 2016 | 02:52 PM
shedhunter32's Avatar
Manual Steering Gearbox 88 pickup
I have an 88 toyota pickup and i tore the splines on the steering gear. I have been looking for a new steering gear and all i can seem to find are steering gears with hydraulic hookup lines. I bought one from LC engineering and i am curious what i should do with it. I was told not to plug the holes but run a hydraulic line making a loop between the ports. I was wondering what kind of steering i will have with this. Will it be worse than my current manual steering? Should i hold off and wait till i have the money to convert my steering to power? however I never really had an issue with the manual steering before. What should i do?
Old Jun 21, 2016 | 12:55 PM
osv's Avatar
osv
by steering gear you mean steering box? post a link to what you bought at lc engineering.
factory steering boxes are ported for hydro assist, which is what i'm thinking you might have.
Old Jun 22, 2016 | 04:57 AM
http://www.lceperformance.com/IFS-St...-p/2060011.htm
Old Jun 22, 2016 | 07:59 AM
osv's Avatar
osv
here is how it hooks up as a hydro assist steering box: http://www.lcengineering.com/LCInstr...ar/2060064.pdf
not shown there is the power steering pump that you also have to hook up to the steering box... i guess that you could not hook up the hydro assist ram, and just use it as power steering, maybe with toyota factory power steering pump? here is the tg hydro assist pump: https://www.trail-gear.com/TG/PS_Pum...502-1-KIT.aspx
this is a factory power steering box, so your question is how will it work as a manual steering box... i really don't know, but maybe someone else can chime in?
SueLu
Feb 24, 2016 08:23 PM
alva22re
Feb 20, 2016 04:21 PM
goofybud16
Feb 6, 2016 01:29 PM
shooter86314
11
Feb 1, 2016 07:45 AM
Damiandominguez
Jan 28, 2016 01:58 AM
