Sponsored by: CARiD
LSV-BP problems
Old Jan 28, 2011 | 09:28 AM
94Yota4Runner's Avatar
LSV-BP problems
k i gotta question about the LSP-BV. i have a 94 with a V6 4x4 and 4wheel abs on it and auto trans, im having an issue with the pressure at the rear wheel cylinders. i had a suspension that they were not stoping the truck so i raised it put it on stands, put it in drive and brought it up to 40Km/h, hit the brakes and they nearly stopped. they still turned, no matter how hard i pushed on the pedal, i let off, and pushed slowly, felt a slight pop in the pedal and then this time it actually stoped them.
now 2 years ago i replaced the rear lines, due to rott, stupid routing if u ask me was the reason for failure, anyway i think i might have messed up which line went to what hole in the valve, if someone knows if the routing is different bewteen the 90 and 94 years, plaease let me know, thanks also the ABS system on this truck has the actual ABS system located on the driver side wheel well, not the ones powered by the power steering pump
SubiKing
Aug 21, 2021 03:57 AM
theking11863
Mar 19, 2016 09:36 PM
Logz808
Jul 26, 2015 07:09 AM
Jonny246
Jul 24, 2015 12:37 PM
kyletbert
Jul 17, 2015 11:39 AM
