leaking oil with a new head
hope im doing this right....i have a 86 pickup 4x4 22r and i just finished the 4th tair down this week and still leaking oil? i have a new head timing chain water pump and oil pump gasket and its still blowing oil every were? any ideas im lost thanks
Welcome to YotaTech. Yea, probably should have posted this in the newb section but since your here.....
Obvious question; you have the correct gaskets and are installing them correctly ? All sealing surfaces clean ?
Are these gaskets leaking oil after you install them? Is your crankcase venting properly ?
Sounds like either poor gasket installation or too much crankcase pressure or both.
Give us some background on your engine.
i dont know much about it. other than it had a small oil leak...now clue from were
than i blow the head gasket between 3 and 4 and now i have a realy big oil leak
and i have no clue about the crank presure?
jasonty
41
Dec 23, 2018 01:00 PM
