Leads for testing Idle Air Control Valve?
Old 03-29-2010, 03:04 AM
pendrag's Avatar
The Haynes manual (gen 3 4runner) shows a diagram where the tech is testing the IAC valve with some leads connected to a battery (pg 4-16). Am I correct in assuming that means I should connect the leads to the vehicle battery?
Are these 5 ft jumper wire test leads from Autozone what I need to pick up?
Old 03-31-2010, 03:09 PM
brian2sun's Avatar
You need a volt meter to measure the resistance.
Old 04-01-2010, 01:48 PM
pendrag's Avatar
The manual was showing the person applying voltage to see if the solenoid turned.
smthwsn357
05-01-2024 07:28 AM
Charecter1
11-06-2023 10:08 AM
Sleaker
08-26-2020 06:03 AM
coryc85
09-09-2015 06:24 AM
09-04-2015 09:27 AM
Quick Reply: Leads for testing Idle Air Control Valve?
