Sponsored by: CARiD
KNOCK SENSOR WIRING TROUBLE 88 6cyl PU
Old Jun 8, 2009 | 11:24 AM
RetDeputy's Avatar
Greetings All,
Just signed up new to this. My 88 Toy pickup has a code of 52, check engine light is on after about 1700 RPM's
After researching the net, people say the knock sensor wires come out on the left side of the intake above the head, TRUE or FALSE ?
The only wires I find are from the left (drivers) side are injectors wire harness. I do not see any other loose wires or plugs either.
The Block was changed 2 years ago (B-4 I bought this truck) and I found out that the check engine bulb was removed, I replaced the buld, maybe the knock sensor wiring is GONE ? Don't know.
In any case if the wires are not there can I find them from the harness on the right side of the engine compartment and slice a new pigtail in ?
I read a guy welded a bracket on the top of the motor to screww the KS into and rewired and it worked fine?
Any help would be appreciated thanks in advance
not too good at this yet if u can help POST or Email
jimjakmc@hotmail.com
montanatruck
Feb 26, 2017 07:07 AM
nonstop
Jul 24, 2015 06:29 PM
Steven.m.paulk
Jul 24, 2015 01:44 PM
88yodabasket
Jul 13, 2015 01:32 PM
smiley52
Jul 11, 2015 05:16 AM
